Q
Qwerty
In addition you could core holes staggered across the board adhesive will lock boards in position
A new one on me. Which manufacturers recommend this method!?
Discuss Leveling floor with cement board in the Canada Tile Advice area at TilersForums.com.
Cement reinforced faced insulation boards, prime floor, use flexible adhesive to bond to floor, stagger board joints and fix scrim tape. In addition you could core holes staggered across the board adhesive will lock boards in position, you may also need to weight boards until adhesive sets. When adhesive sets you could add additional fixings into concrete although probably not necessary. Good luck.
Never had a board let go without coring holes into them .Not quoting from a manufacturers specification particularly, just successfully method l have used /adapted in the past.
Sand and cement based substrate.Was wondering what do you guys call screed?
This is such a confusing read from start to end.
Be quicker to & better to self level. No faffing about then.
What is coring a hole in them?
Reply to Leveling floor with cement board in the Canada Tile Advice area at TilersForums.com
