Discuss Tiling Anhydrite screed with wet UFH in the Tile Adhesive / Grout Advice area at TilersForums.com.
TheAofT
263
Reading
No head butting going on here... I accept that from a technical perspective you could use 1 joint. In ust think 2, evenly spaced, making 5mx5m bays would make it more robust. My real concern though is the 3mm grout joint. I'e just done some calcs based on the coefficient of linear thermal expansion of porcelain, wich is about 4x that of the screed. Each tile based on a change of temperature from 5degrees up to 25degrees (I.e a cold floor up to an operational surface temp) would expand by 0.64mm so about 0.3mm in each direction. That is 10% of the grout joint width at 3mm which will place huge stress on the joint. I don' know the compressive strengths or coefficient of linear compaction for grout so csnnot say if it will accomodate that level of movement. It does worry me though...
I guess, having a slightly paranoid streak I just don' want the floor to fail and the screed to get the blame as it often does...
Hi Alan,
I've found some info (picture attached) on the compressive strength for Mapei ultra colour grout as an example.
Unfortunately, couldn't find any data on BAL, Weber, Ultra, and Nicobond to compare but pretty sure they all in the same category.
In you opinion....
Would the 3mm joint filled with Mapei accommodate that level of movement.
So I’ve had time to sit, read and digest your post now Alan, and these are my thoughts on it.
Most of the time we fit tiles at room temperature, typically around 18 degrees, so as long as the tiles have acclimatised, they too are going to be around that temperature.
So given that the temperature of the tiles is increased to the 25 degrees that you mentioned, as a comfortable underfoot temperature, the actual temperature range is from 18/19 to 25 degrees, in fact only an increase of around 6/7 degrees, how would that effect your calculations?
Because if they do start at around room temperature, and the floor gets colder the tiles will already be in an expansive state, so therefor it would follow that they would contract, making the joint wider effectively.
I appreciate I’m kinda splitting hairs a little but it seems that everything is balanced on a knifes edge these days, so it may well come down to being a little pedantic.
Sod all would get done otherwise. :D
Really good points raised there but I am not trying to be smart or too pedantic . But most wet floor systems I have worked on have had air stats so to get the room into that comfort zone temperature spread does anybody know what temp the floor slab would be run at .
Alan stated above that an operational surface temperature of 25 degrees.
Ajax123
1,213
Lincolnshire
I calculated based on an uplift of 20 degrees from 5 to 25 so you are quite correct that a smaller uplift would lead to less expansion. It would be approximately a third so 0.1mm in any direction. I'm not absolutely certain how this translates to a compressive force so need to think on it more.
Interesting that i would of thought that porcelain was dimensionally more stable than the screed . Everyday is a skool day
Does a movement joint compensate for tighter grout joints? Is a smaller joint more acceptable with a smaller tile - more joints and a larger joint with large tiles ?
Ajax123
1,213
Lincolnshire
Yes a movement joint would mitigate some of the risk as it would help alleviate stress by allowing free movement. Yes smaller tiles allows thinner joints as the movement per tile is less.
Ajax123
1,213
Lincolnshire
Porcelain has a coefficient of linear thermal expansion of 4 whereas anhydrite is 0.12 both x10 to -6 m/mK based on the engineering values I have. Sand cement is much higher than anhydrite hence the need for fewer joints in anhydrite screeds...
R
Richard Head
Thanks again to everybody for their input. I'm glad my post has prompted a debate which I've found really helpful in understanding the issues.
I am hugely relieved that a decoupling layer is not required - this was going to cause me the greatest headache of all and even more costs. I am perfectly relaxed about putting in extra hard or soft expansion joints and realise now that it doesn't matter that these aren't structural joints carried through the screed. The plan is to go for two, dividing the floor into 3 x 5x5m bays, as Ajax suggested.
I am inclined to stick to 3mm grout lines for aesthetic reasons and because the tiles are rectified (10mm thick). I had a long and very helpful chat with a technical guy at Tilemaster who was happy with this provided sufficient expansion joints were provided. I might incorporate additional soft joints if I start having sleepless nights worrying about this.
Ajax, I wonder in the failure case you mentioned whether expansion joints had been provided? and who picked up the tab for the remedial work. I'm guessing it would have been a big number.
In a similar vein, I wonder whether any supplier of materials would provide a watertight guarantee provided they were happy with the specification. Of course, if the job really did go belly up, the first port of call would be the tiler who did the work but I suspect that wouldn't get me very far. In my experience, the customer always end up paying when things go wrong since it's always deemed to be his fault!
Thanks again to one and all
Cheers, Jonathan
Reply to Tiling Anhydrite screed with wet UFH in the Tile Adhesive / Grout Advice area at TilersForums.com
