Youd need to confirm that with schluter but I don' think so as ditra is only for relief of lateral stress as far as I know.
Discuss Tiling Anhydrite screed with wet UFH in the Tile Adhesive / Grout Advice area at TilersForums.com.
I did, actually.Youd need to confirm that with schluter but I don' think so as ditra is only for relief of lateral stress as far as I know.
What did they say out of interestI did, actually.
Thank you for your advice.
What size of grout line would you suggest to accommodate all the tension?
Mainly it designed for uncoupling or separating the floor covering from the substrate and prevents the transfer of stresses to the tiled surface. In this way, a deformation or crack caused by shrinkage in the substrate is neutralized. The mat bridges the cracks and does not allow the transfer of this energy to the tiled surface.What did they say out of interest
Reply to Tiling Anhydrite screed with wet UFH in the Tile Adhesive / Grout Advice area at TilersForums.com
