Discuss Two loose tiles - effcient way to fix this in the Tile Adhesive / Grout Advice area at TilersForums.com.
Diddums
ok i have stuck it down using the adhesive but im not sure i used enough . Im tempted to get some quotes for removing all the tiles, putting plyboard down and putting the tiles back on. Its a very small bathroom and i dont need new tiles. and i have about 4kg of adhesive now :(
If i am to get quotes then should i say that this is what i want the tiler to do ? id be more impressed by a tiler who would say that plywood needs to be put down above the chipboard first as i would assume they were more knowledgable and experienced
WetSaw
I'd be happier if the tiler said he was going to use a proper tile backer board rather than ply. Looking at the tile that came up you could probably save yourself some money by lifting the rest yourself and cleaning up the old adhesive.
Tommythetiler80
Soaking tiles in a soapy solution has helped me in the past when I've had to rescue tiles ,normally 24 hours does the trick,then a bladed scraper to remove any stubborn addy from the back of tiles.
On one
It works on ready mixed tubbed adhesive, on a cement based adhesive might be a different matter.(Can't tell from the photo)
On one
What makes you think you don't need new tiles? you haven't got all of the old tiles up and cleaned off yet.
R
RayL12
Hi all, :)
Still at student stage, myself so, this a searching question.
The tiles are fixed to a chipboard, which, from my roofing days, I noticed had many problems. Sagging was a major one.
Otherwise, given the amount of movement chipboard has both as a whole board or, indeed, in local areas, would you say that the very tight bond of the tiles only increases the problem of lift?
Ray.
Time's Ran Out
Ray - best start a new thread!
Op - put a mat over it and don't put it in your documents when you move.
cuemanlew
job looks wrong, chipboard is a no no, for a quick fix use a flexible silicone, regrout hope for the best. If other tiles come loose then its a floor up job and hopefully done right next time.
R
RayL12
Sorry for the confusion, John and, the late response.
First, my comment was to answer the problem with chipboard in my experience while a roofer.
The phrase' searching question' was way off mark. What I meant by that is, I'm not a experienced tiler and that, tilers may have a different opinion on chipboard, that, I may learn something regarding tiling and chipboard.
Hope I make myself clearer.
Ray.
Reply to Two loose tiles - effcient way to fix this in the Tile Adhesive / Grout Advice area at TilersForums.com
