Discuss Heated walls in bathrooms in the Canada area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
I've got my schluter pack through today, couple of freebies and some papers, just reading about the ditra heat on the walls, and the ditra heat duo which I hadn't heard of. Has anyone fitted it on the walls? I'm keen to!
Dan
Admin
That sounds cool! Never thought of that but it totally makes sense!
Spacing the heating cable every two nibs instead of three increase output to around 200w and is sufficient for a primary heat source.
That's if I remember correctly. :D
Does away with rads and heated towel rails in bathrooms which are normally tight enough for space as it is.
I remember reading on one ufh supplier years ago not to run it up walls but never understood why.
Yes I will deffinately. Is there one course which covers everything or different ones
Reply to Heated walls in bathrooms in the Canada area at TilersForums.com
Apatel
