Discuss need to cut a 65mm hole in the UK Tiling Forum area at TilersForums.com.
H
howard
hi guys
i need to cut a 65mm hole in a porcelain tile ive checked out the 365 drills but its not worth buying for a one off job any ideas how to do this
cheers
howard
Olz
Hire shop maybe ?
Or a very nice tiling friend in your area who may have one he / she could lend you?
Oli
NickH
388
How tidy does it have to be ? If its going to be covered you could use a 4 inch grinder to cut through from both sides in an asterix pattern, if you know what I mean, and try to nibble the rest out.
H
howard
its for a flush button on a toilet i have about 5mm to play with
brian c
I agree with Nick,use a grinder or set out to half the hole with two tiles if its not too late.
Olz
Just price the hole cutter in with the job..........:thumbsup:
Cousin is a Pluber and Gas Fitter, he often does this, if the tool he needs is expensive he sacrifices some profit margin, but next time he needs it he has it so no biggy really.
He has some expensive kit for gas flow testing and stuff, all of the cost is absorbed into jobs here and their, He just whacks stuff on the credit card and pays it off after the job, earns cashback / loyalty points on the credit card too.
DHTiling
Then get the customer to order the hole cutter if they want it done......then they might be kind and give it to you once done......:grin:
Reply to need to cut a 65mm hole in the UK Tiling Forum area at TilersForums.com
  • Sticky
