Discuss Floor preperation advice in the Canada Tile Advice area at TilersForums.com.
mma
I've got to build up a floor at home ASAP, as a new kitchen is being delivered on Friday, and it needs to be tiled before then.
Issue is that the floor runs out 40mm so was thinking about using 40mm insulated boards. My usual tile place only stock up to 20mm.
So, any other options? Or where can I get decent 40mm boards quickly?
mma
No CTD near me. Was hoping to pick some boards up tomorrow and found a place in Notts that do 40mm ones, if in stock.
Would it work what @Tile seller said? It did cross my mind!
mma
Schluter isn't too far from me but don't think that you can buy direct from them?
WetSaw
Does the whole floor need 40mm to be level with another floor/room or is it just not level and the worst part is 40mm low?
Reply to Floor preperation advice in the Canada Tile Advice area at TilersForums.com
