square sticking
Hi,
I am tiling my bathroom with 300x600 rectified tiles but am finding that they are bowing once the adhesive has dried.
I have checked that the tiles are true on the front face of the tile both vertically and horizontally prior to fitting and all is flat, once fitted all is still ok, however once dry the centre section of the tile seems to get sucked in. Edge to edge is fine and no lippage can be felt and as I am not laying them in a brick pattern it isn't a big issue but would like to know if this is a recognised thing that can happen and if I can stop it from happening to the rest that I still have to fit.
I am using a bal adhesive and have the bowing happen when tiling on hardbacker and wendi board. I am using a Rubi 10mm square notch trowel and applying 1mm of adhesive to the back of the tile prior to fitment.
I guess once fitted the adhesive depth is 5 to 6mm.
The grouting hasn't been done yet and I have used 2mm Rubi tile spacers.
The tiles themselves are about 8mm thick and cost £700 for 10m2 at trade prices and seem to me to be decent quality.
The first photo is vertical and the second horizontal. The bowing isn't due to a curve in the steel rule,it is there whatever side of the ruler I use !
Thanks in advance Pete
