Discuss Cut Of The Day- Show Yours! in the Australia Tiling Forum area at TilersForums.com.
Something doesn't stack up here, did you split the tile somewhere?last couple before I hit the hay for work tomorrow. Cut using a angle grinder round a door frame. 600x600 fully vitrified heartwood. Again really easy cut haha
View attachment 77335 View attachment 77336 View attachment 77337
Haha no apologies necessary Lee.Dynamictiling 3_fall apologies for the confusion
Ok thanksHaha no apologies necessary Lee.
If u want to attract a particular member put the @ symbol before their Avatar name and then it will be clear to that person, they will be notified!
@LEE MAC
Am I the only one who uses rubber tiles? Haha after much persistence and patience... it didn't fit and I had to (grudgingly) split the small 'c' section of the tile at the part that ran under the cupboard door and piece it in. Good spot Lee ;-)
I think what ali means is did you have to split the tile to get the cut in around the doorway or did you cut at the actual door frame to slide the tile in?last couple before I hit the hay for work tomorrow. Cut using a angle grinder round a door frame. 600x600 fully vitrified heartwood. Again really easy cut haha
Whoops should of read on sorry folksI think what ali means is did you have to split the tile to get the cut in around the doorway or did you cut at the actual door frame to slide the tile in?
If im honest andy, i have mine outside, skunk can stink the house out, customers can be funny buggersWhere possible I always try and have a joint in the doorway. .....makes life alot easier. .
@widler I have got to say..... those cuts are outstanding mate. You have made a sterling job of that :-D
Ha ha, funny
Rumbled , ok all the skirts/doors/ arcs were not on and the stairs were put in after , I hate you all
Reply to Cut Of The Day- Show Yours! in the Australia Tiling Forum area at TilersForums.com
