Discuss High Temperature Tile Adhesive in the Australia Tiling Forum area at TilersForums.com.
Ian
Went to look at a BBQ/fire pit today and the customer would like it tiled inside using brick slips, what sort of adhesive is going to be suitable to take those sort of temps! Probably 250/300 Celsius. I've had a look at a couple of PDFs of tilemaster products but can't find the required info. Just thought I'd ask before I ring technical help in the morning. It'll be gas by the way so no hot coals will be in the base.
Ajax123
1,213
Lincolnshire
I think the brick slips would suffer more than the adhesive. I would think they would undergo spalling quite quickly.
Ian
They're cut from blue engineering bricks Alan so, I'm fairly happy they'll be ok. It's the adhesive that's my problem, so to speak, that's the bit I don't want to fail.
Ajax123
1,213
Lincolnshire
Oh ok bri. Interesting one. Sadly I have no answer but interested if you get one.
Dave
Subscribed
1,000,000
Co.Durham
I saw that on a Google search Dave, found it a bit odd that it's ready mixed and it can only be bedded up to 3mm, sounds a bit too similar to dispersion adhesive to me. I'll be sticking them straight to blockwork and I'm not convinced it'll be flat or smooth enough for a 3mm bed.
Some fire adhesives are tubbed , have a look at fire cement as well....
Most tile adhesives are only suitable to 100dgs if I recall rightly , so high temp fire adhesive like you say is required.
R
Rizzle from the Portizzle
this depends on what the back ground the tiles are fixed to and how that can handle the heat tile master ultamat should handle the heat but if it cant pass some of that back to the substrate it may be a problem
Reply to High Temperature Tile Adhesive in the Australia Tiling Forum area at TilersForums.com
  • Poll
