Discuss Tiling onto cement render in the Canada Tile Advice area at TilersForums.com.
dickiem
Hi, newbie (DIYer) hoping for some help.
I'm tiling my bathroom onto new cement render, how long do I need to leave the render before putting the tiles on?
White Room
Hi and welcome.....they do say 4 weeks, how long has it been since it was rendered.
The Legend; Phil Hobson RIP
How thick is the render? rule of thumb same as screed 1mm per day.
Sorry Mark posted at the same time, four weeks is what we used to work on.:thumbsup:
Ajax123
1,213
Lincolnshire
Agreed four weeks.... Or 28 days. This is because all strength testing on cement based materials is based on 28day tests.
dickiem
Hi, thanks for the replies.
It will all be 'rendered' this week. It's not actually a full render, it's various thicknesses (up to probably 5mm max) in patches merely to flatten the blockwork and to give a level surface for tiling onto. I've used a 4 to 1 to 1, sand:cement:lime mix.
It'll be a bummer if I have to wait 4 weeks, the bathroom is a right mess as you'd expect:oops:
nybor62
1,083
rotherham
why not dot and dab some new board on to the wall , putting render on as thin as that imo , will not be sound enough
other,s may have a different view on it
dickiem
Hi,
My room is very narrow and I've had to go back to block to maximise the width I have in order to accommodate a vanity unit and the bath with a bit of clearance. With plaster or dot n dab I would end up with insufficient width to get everything in:-/
White Room
You should be putting 12mm render for one coat so it gives you a chance to flatten out, 5mm may lose some strength with that thickness and find difficult to level out.
dickiem
I only have 'patches' where the aggregate block faces aren't flush but some are the size of a couple of blocks. 12mm reduction either side of the room would leave me insufficient overall width to fit the bath and vanity. Guess I'm stuck with what I've got so have to hope it's sound enough:-/ I wish I hadn't started now:-(
Reply to Tiling onto cement render in the Canada Tile Advice area at TilersForums.com
