Travertine Tile Help!!!!
cheeseboy7
Hello, i am new to this forum and would really appreciate your help on the following questions. I apologise if these questions have already been asked before.
My girlfriend has just bought some Travertine tiles from B&Q (600mm x 400mm) for our bathroom and i have to fit them. However i need help on the following things:
1. I didn't realise that these tiles had to be sealed. Please advise what sealant i need and when i apply it (ie after/before grouting).
2. What tools do i need to use to cut tiles. They are 10mm thick. I only need to cut straight edges.
3. What is the best/strongest adveshive that i should use? They are very heavy and i'm worried they won't hold on the walls.
4. What does it mean by them being honed and filled? I haven't got a clue if this is something i need to additionally do.
Any others tips/advice would be appreciated.
I really appreciate you help in answering these questions.
Thanks.
welcome to forums cheeseboy.
1. i use lithofin stain stop to seal this type of tile 2 coats before grouting and 1 after.
2. you wil need to use a wet cutter only to cut them.
3. you will need to use a single part flexible powder adhesive for theses tiles ( preferably white just to make sure of no staining of tile ). and use a flexible grout.
4.travertine when first mined is full of holes and imperfections , so honed and filled is when the holes and imperfections are filled with a mixture of travertine dust and resin binded together to make a paste which is then used as the filler then the travertine is polished to a smooth textured surface and then cut into its required sizes. hence the phraise honed and filled. lol.
as you are using a powdered adhesive you will need to prime the walls first , use bal bond sbr or bal apd.
and finaly good luck and post some pics dave.......
You said that these tiles are going on the wall, if so has the wall been plastered, if it has you will need to dot & dab plasterboard onto it as these tiles may be too heavy and just pull the plaster off the walls.
plaster can take weight up to 20kg psm
plasterboard can support weight up to 32kg psm
Something else to think about :wink_smile:
i would seal twice before fitting these tiles mate just to be on the safe side as i assume you have not done a lot of tiling before then seal again after grouting but make sure the tiles are spotlessly clean and free from dust
Guy, can I jump in and ask an additional question on this? As you say, make sure the tiles are clean before applying the lithofin. What is the best way to clean them prior to 1st sealing coat (and later ones for that matter)? I'm laying travertine floor tiles, rather than wall..
Tx, mate.
Before they have been layed the tiles should really only need dusting down with a dry clth/towel, but if they are a bit dirty then just clean them with sponge and water before first seal.
do as varley says but dont soak them in water to clean them as they will absorb the water just use a damp sponge
Cheers guys, appreciated. They are super-delicate, I picked up a 200x400 cut tile longways and it broke in my hand..... I assume you have to back-butter and make sure adhesive very well spread or they'll crack easy? I'm also tiling under range cooker and large free-standing fridge-freezer, so any advice on avoiding cracks?
Tx help again.
Tx help again.
use a solid bed trowel and back butter tiles to achieve a solid for your tiles and you will have no bother with any appliances, would be wise to use white spf adhesive and clean any excess of as you go.. check for any fracture lines in tiles before fixing and try and use them for cuts etc.. dave...
Got some 200 X 200 travatine to put on a bathroom wall can i use bal white star or will this not be suitable?
Vince.
better to use white spf adhesive as this is still quite heavy tile and spf will hold better...
WTF, are you trying to kill people? You are right in saying that plaster can take 20kg psm. However, if you dot and dab plasterboard onto it the original plaster then has to take the weight of the plasterboard as well as the tiles. The plasterboard will take the weight of the tiles but the whole lot will fall off the plaster.
Hopefully this hasn't been done. If it's not too late then you need to strip the plaster off the wall and dot and dab plasterboard to the breeze block or mechanically fix some plasterboard.
Your absolutely right mate, I wasn't very clear in that post :embaressed_smile:
Just lloking @ your thread, I'm about to fix travertine to a stud wall, the weight of the tiles is 28kg/square meter.
Will a stud wall support this material, I'm only fixing upto 1200mm from the floor.
Andrew
Hi gang I'm a newbie here and hope someone can help. I did a google for Travertine help and landed up here , so here goes.
I do total bathroom renovations and on a recent job the client took a fancy to a large 600 sq travertine. its about 18mm thick. These were laid on a very stiff WBP 1" ply floor. The floor has a 8mm heating trace inset linked to the towel warmer.
The tiles were laid with a flex dry powder adhesive ( bal if memory serves ) and grouted with Mapei flex grout.
Here is the problem. All was well for 3 months or so and then gradually some of the tiles have split. Strangely the splits follow the joint lines between the plywood. The ply and all the floor is very solid as the owner is a big laddie.
The ply is screwed down to the joists and the joists are reinforced with props to the solum, so it is all very stiff with no 'bounce'
My initial thought was that the heating had caused the issue but there is a tile that has no heating under it that has split also, so that kind of rules that out.
There are also tiles with heating that have not split.
The only thing that I can think of is that the tiles may have shrunk somewhat. Could it be the case that if they had been stored outside or in damp conditions that they would behave in the same way as timber ?
None of the tiles have come loose in any way.
I hope someone can throw some light on this for me as for now I am at a complete loss.:mad2:
Thanks in advance, Mac
Hi.
Been in contact with a branch and they have advised the below.
1. I didn't realise that these tiles had to be sealed. Please advise what sealant I need and when I apply it (ie after/before grouting).
Use Lithofin Stain Stop. Treat the face of the tile before starting. Use a rag or roller to apply. It might need a couple of coats. Once you have grouted, and it is all clean, it might be worth re-doing the sealant to keep it all fresh and new. It will need to be re-sealed with Lithofin every few years depending on the level of use. Floors might need more often than walls. This product should not affect the colour or finish of the tiles.
2. What tools do I need to use to cut tiles. They are 10mm thick. I only need to cut straight edges.
An angle grinder will work, or an electric tile cutter. If it’s an electric tile cutter you may need a fairly hefty watt motor, for example 600w or above, ideally about 800w with a diamond blade. Straight edges could be cut using a score and snap such as a Rubi TS60, these can normally be loaned out from your local CTD, or visit a generic Hire Shop. If you need to drill them, for example to fit a toothbrush holder, use a masonry drill, or one of the Armeg drills. Larger holes such as waste pipes could also be cut using the Armeg drill sets.
3. What is the best/strongest adhesive that I should use? They are very heavy and I'm worried they won't hold on the walls.
For a 600x400 tile, you will need something fairly strong. There is a lot of weight in them. Also as it’s a light coloured natural tile, you will need a white coloured adhesive. If its going onto walls or floors I would use the BAL Rapidset White (for solid surfaces such as brick or concrete) or BAL Rapidset Flexible White (for flexible surfaces such as timber or plasterboard).
The walls will have a weight limit, but this will depend on the material the wall is made from. Ideally, you need to board the walls with something like Hardi Tile backer board or WEDI board, which will far exceed the weight limit of those tiles. If the wall is plastered, then you only have about 20kg per m2, which for that kind of tile would be a bit tight. If the wall is bare plasterboard you have about 32kg per m2, which will prob work, but doesn’t allow much room for comfort. If the wall is bare brick/stone etc then it should be ok. Make sure that the tiles have a good coverage of adhesive. Allow extra time from that recommended on the packaging before grouting, to make absolutely sure that it has cured totally.
4. What does it mean by them being honed and filled? I haven't got a clue if this is something I need to additionally do.
Honed and filled is a process that the tile has already been through, and refers to the fact that it feels smooth to the touch. When it was quarried, there were holes in the surface of the stone naturally. These have been filled with a resin so that the surface is smooth now. Ideally the tile should be flat bottomed, for ease of installation. You don’t need to “do” anything.
Natural stone is inherently porus. Even with the sealer etc, it may be possible for water to pass through the tiles under pressure, for example if you have a power shower. Ideally, you should tank the walls to make sure that if any water does get through, it wont cause any damage to your walls or floors. Something like the Homelux Tanking Mats would be appropriate, or if you are using Hardi Backer Boards, or WEDI boards, then these are waterproof in themselves. Natural stone is one of those products that looks great when in, but just requires a bit of tender love and care. Ideally get a tiler in to install it for you.
Hope this is of some help.
:yes:
cheeseboy7,
CTD Marie,
cheeseboy7,
CTD Marie,
