Fireplace???
E
elsdevine
Hiya! Was asked to fix a few broken tiles on a fireplace - wasn't sure if there is specialist adhesive/grout for them??
cheers...
elaine!
you should use a flex adhesive to fix because of the movement caused by the heat when the fire is on
hi elaine. if you just use 2 pack flexi adhesive and grout will be fine, there are a few companys sell products for fireplaces but 2 pack will be fine. dave......
No need for a 2 part flex adhesive on a standard fireplace,standard flexible adhesive is only needed with wood burners, where the heat is fierce
Fireplace???
elsdevine,
GazTech,
elsdevine,
GazTech,
