K
kickkick
Hi Guys.
I have a small bathroom floor about 5 square metre. The problem is this.
The house is a chalet bungalow and the bathroom up in the roof space along with the bedrooms etc.
The chip board flooring is fixed to the roof trusts. Then the floor has been over boarded with the correct size plywood with expansion gaps and screwed down in the correct fashion. Now because the roof trusts are prone to normal building movment I have a concern that the plywood is also screwed to the chipboard floor then there final finsh would result in cracked tiles etc etc. I was wondering if this sort of problem would be solved but using Ditra Matting over the plywood and thrust avoid the problems that the roof trusts can bring.
Many Thanks
Karl.
Many Thanks
Karl.
