Discuss Would this be a job for Dita to be used? in the UK Tiling Forum area at TilersForums.com.
K
kickkick
Hi Guys.
I have a small bathroom floor about 5 square metre. The problem is this.
The house is a chalet bungalow and the bathroom up in the roof space along with the bedrooms etc.
The chip board flooring is fixed to the roof trusts. Then the floor has been over boarded with the correct size plywood with expansion gaps and screwed down in the correct fashion. Now because the roof trusts are prone to normal building movment I have a concern that the plywood is also screwed to the chipboard floor then there final finsh would result in cracked tiles etc etc. I was wondering if this sort of problem would be solved but using Ditra Matting over the plywood and thrust avoid the problems that the roof trusts can bring.
Many Thanks
Karl.
DHTiling
Is the floor deflection free...if it is then Ditra will be useful against lateral stress cracks...transfering to the tiles..
doug boardley
but if the roof trusses move the floor up and down it would, imo, be a job for 6mm hardiebacker
DHTiling
If it moves up and down doug....then no tiling it, till it's sorted...:smilewinkgrin:
K
kickkick
Nah the roof turst done move up and down thank god. Just normal side to side movement of a few mm.
Thank you for your great input. I must really post hear more often and get involved as I have been reading the forum for a few years with no input.
mikethetile
have i understood you right
the floor is laid direct on the ceiling joist of the roof truss.............surely not
"joists dont deflect up and down but deflect sideways by a couple of mm"
im hoping youve got this wrong mate and the floor isnt laid on the cross ties of trada trusses
your floor joists should be around about 200mm x 50mm at either 400 or 600 centres depending on span
if they are 100 -150 they are ceiling joists only and not intended to take a floor
if you fit out a fully tiled and fitted bathroom in the loft it will only be a matter of time before you have a new downstairs bathroom
please check the dimensions of the joists before going any further, many chalet bungalows were intended to have the loft floored and used for occasional use and storage of light items they were never intended to be used as living space
im sorry to be like this with you mate but i dont want to see you coming unstuck in the future
hoping you have got floor joists
mike
K
kickkick
mike
Yes you are correct. I did forget to mention that there is indeed joist spanning across the building between the roof trusts, and the upstairs floor is indeed fixed to the joists and not the roof trusts.
Do you still think there would be alot of movement then if the floor it fixed to joists?
doug boardley
any chance of some scaled pictures kickkick, it's sounding dubious to say the least:thumbsdown:
mikethetile
you had me extremely worried there karl
to the point of ringing building control
you have no trusses in your chalet bungalow , which is a relief, you have what we call a cut roof
which basicly means cut and fitted in situ
the floor joists act as the lower tie and the ceiling joists over your head act as the collar or upper tie
so treat the floor as any suspended wooden floor
youve got very little deflection which is good , theres going to be some deflection on a suspended wood floor, but where does the sideways movement come in
if your floor joists have sideways movement you will need to lift the flooring and add noggins to take out the movement and relay the flooring
at the same time dump the chipboard floor and scew 18mm ply direct to your floor joists
Reply to Would this be a job for Dita to be used? in the UK Tiling Forum area at TilersForums.com
