I see said the blind manIt’s 3 Jerry, enlarge the image and look closely at the pipes.
Don't worry if you were trolling that went over my headSorry. Was trolling.
F
Balanced if the mass of the balls are the same. Doesn't matter about weight it's water displacement so based on size.
4 for the first one, it'd fill because of the pressure but if you turn the tap off it'd also be the last one with water in and wouldn't empty fully.
You would think eh!Balanced if the mass of the balls are the same. Doesn't matter about weight it's water displacement so based on size.
Density difference?Balanced if the mass of the balls are the same. Doesn't matter about weight it's water displacement so based on size.
135Temporary hijack of your thread Marc....... give this one a go people!!!!.....
Whoops make that 90Temporary hijack of your thread Marc....... give this one a go people!!!!.....
You don't miss much Paul😉
275Temporary hijack of your thread Marc....... give this one a go people!!!!.....
