Discuss Where can I get a triange shape hole cutter? in the UK Tiling Forum area at TilersForums.com.
doug boardley
Bolter, do you find tho' that the hole it leaves is more like a 50p shape than a true circle?
K
kaharrison9
Well desribed Doug
Not yet been able to acheive a nice circle in ceramic always end up with a 50p shape.
Have built up a fair set of 365 drill pieces couldn't be any easier.
E
essexsi
Thanks for all your replies.
I only require it for drilling two 15mm holes in ceramic tiles for my one off Diy shower room job. Didn't really think I would need anything more substantial!
Cheers for your input. Si
Bolter
Only if you go in to far one way.
I mean, its always possible to mess a hole up, I still mess up even an L shape cut on occassion :D But it is possible to make this tool work. The secret is in going through the back, and then the front a little, and then the back again. The bigger the hole though, the trickier it is, and I wouldnt attempt anything over sink waste size.
Ajax123
1,213
Lincolnshire
why you want cut triangle shaped holes....:lol:
Reply to Where can I get a triange shape hole cutter? in the UK Tiling Forum area at TilersForums.com
