Discuss Where can I get a triange shape hole cutter? in the UK Tiling Forum area at TilersForums.com.
Bolter
Ive got one, and I think its awesome for ceramic tiles. Trick is to mark the tile on the back of the tile, and start the hole in the back. Once a 5mm hole appears, turn the tile over and repeat. May need to turn the tile 4 times to make a hole big enough and neat enough for a sink waste pipe. Had mine for a year or so, use it almost daily, and i still makes perfect holes.
Bolter
Bolter, do you find tho' that the hole it leaves is more like a 50p shape than a true circle?
Only if you go in to far one way.
I mean, its always possible to mess a hole up, I still mess up even an L shape cut on occassion :D But it is possible to make this tool work. The secret is in going through the back, and then the front a little, and then the back again. The bigger the hole though, the trickier it is, and I wouldnt attempt anything over sink waste size.
Reply to Where can I get a triange shape hole cutter? in the UK Tiling Forum area at TilersForums.com
  • Sticky
  • Question
  • Question
