Discuss Washboy Woes in the Tile Tools | any Country any make any model area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
K
Kevbos
View attachment 82228 got the washboy out today for the first time in a long time to give it another go. Still not having much joy with it. Creates a lot of foaming on the tiles and on the joints! Any ideas ?
I'm ringing it out a lot.
You may hear many stories about washboys. Most untrue. That sponge you used was not segmented and cheap. And not worn in. A washboys used properly is by far the best way to leave smooth joints. That bubbling is from using to wet a grout and to new a sponge.
L
LM
Your problem is too much water, so somethings wrong along those lines, maybe the sponge quality is poor or your roller system isn't draining enough water when you pass your sponge over it
L
LM
I mean this in a nice way, but are you drawing the float slowly across the floor hence allowing the sponge to 'soak' up the water that's in the floor :)
F
Flintstone
Not particularly slow, just a general sweep over. Ile get myself a new sponge and try some more different techniques with it. Think it's a rubi washboy
L
LM
The more absorbant the sponge the quicker it'll soak up the water. Try Diatech's segmented sponges, they are stuck on with spray adhesive, are very good value and do a really good job
Reply to Washboy Woes in the Tile Tools | any Country any make any model area at TilersForums.com
laattaana
