Discuss Twelve cracked thin porcelain tiles 1500x1500 in the Tiling on Underfloor Heating area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Hello!
We have an issue with 12 cracked large format thin porcelain tiles (1500x1500x6mm). They all have cracked in L cuts.
The floor is made of concrete (they call it dry concrete or estrich over here). The tiles were laid 6 months after pouring the concrete in. It has underfloor heating that was commissioned slowly by no more than 2 degrees per day, but outgoing water did reach a high of 43 degrees celsius and the tiles were covered with foamy 5mm material as well as 5mm thick material that is similar to chipboard, but more like paper.
The adhesive used is Ceresit CM22 which is called (Mega Format Flexible). They made sure that all cracks in concrete are no more than 15 cm away from the grout lines. No membrane was used.
The tilers did not drill a hole in the tiles before cutting the L cut as they say it is only to avoid cracks in the cutting process. Afterwards these drilled holes get cleaned out anyway according to them. The tilers say the reason is the high maximum temperature of the floor combined with the 6mm thickness of the tiles. Would you buy that explaination?
What could be the reason here? What could we do to avoid this in the future? Should the builders or tilers be financially responsible for the damaged materials?
JASON
6mm they sound to thin for a floor but I don’t no the spec of the tile. pull a tile and look did they back butter the tile to get good covarge. Tile will have to come up to see did the floor crack where the tile cracked anyway
Best of look with the blame game that’s going to happen tiler will blame builder builder will blame screed and tiler and it will go around and around
Anthony
Personally I’d say they’re to thin.having 12 gone that way to me proves that, L shape cuts (check outs) massively weakens the tile,even in tiles double your thickness, add ufh into that aswell wouldn’t help.
After you cut them, then spread the back and a man at each corner,
The weight on that tile,of that size and thickness could of started the fracture process before it was even fixed!
Also 10mm thick tiles are the recommended size to use with ufh!
bsc ceramics
Did the builder put the skirting boards straight down on the tiles? if so as said sounds like stress cracks.
6mm is fine for the floor. do you have any pics
Reply to Twelve cracked thin porcelain tiles 1500x1500 in the Tiling on Underfloor Heating area at TilersForums.com
Apatel
