Discuss Tiling and underfloor heating help in the The Welcome Forum area at TilersForums.com.
Mark wemyss
evening
Laid isoscreed/anhydrite at 65mm on the 21/3/17 Ina new build property over underfloor pipes laid into inserts
Screed has since been sanded ready to receive the floor tiles.
Question is do I need to switch the ufh on? And if I do for how long (a day or a week etc)
Sorry for the newbie question but heard different reports where the ufh needs to be on for 2 weeks and off for 2 and others not on at all and just simply install the tiles
Any help welcome
Many thanks
F
Flintstone
I stand to be corrected on the exact times but I think it's switch it on low and work it up By maximum of 5 degrees per day until you reach a high temp. then run it for a week at high temp. Then reduce it over a few days and switch it off 48 hours before tiling
Mark wemyss
Hygrometer will be going on it tommorow to double check.
If it is within the limit am I good to tile or does the ufh need to be switched on
Uheat - Jake
TF Official Sponsor
Points
743
As the system is used for first time, the mixing valve must be set to minimum setting to let the moisture in the screed to dry out. The temperature should be increased by 2 degrees every day until the mixing valve is set at 45°C (about 5 days).
Once the mixing valve is set to:
45°C for Screed Floor
55°C for Timber Suspended Floor with Aluminum Spreader Plates
set the room thermostats to required levels and programme the system controls to run as required.
Chalker
Points
1,058
Tadcaster
You will be amazed how much moisture will come out of the screed once the ufh is turned on.
As above, it needs commissioning before tiling
Reply to Tiling and underfloor heating help in the The Welcome Forum area at TilersForums.com
A little help guys. I've been asked to price 71sqm of limestone flooring. My issue is this...
