Discuss Tiling a bath panel ??? in the Australia Tiling Forum area at TilersForums.com.
R
Ruel Miah
hi guys I’m going to tile my bath panel well I’d like to but not sure how to go about it i was thinking of using tile backer board but the bath is a 1600 and I can only find boards that come in 1200 lengths.......how would you guys approach this ???
Ive always used 9/12/18 ml plyboard.
Does the job. But would depend on how much slack you have to get a finish
No need for fancy fittings in my view.
I just finish this job with 5.5ml ply. Screwed 3 baton Boxes behind to make more rigid.
Turned out as in pic
Waluigi
instead of the acrylic panels I specify wooden panels. Well it’s MDF with an acrylic coating. Usually consists of a top large panel and a set back plinth. The plinth rides up behind the top panel which not only takes up any irregularities in the floor level but also means that the bath height in relation to the final floor finish is far less important.
These panels shouldn’t be confused with the vinyl wrapped panels which are of an inferior quality.
LEH
108
Oxford
Funny how much argument tiled bath panels cause. I remember going through all the discussions when I was planning my (DIY) bathroom some time ago. I think they look nice and higher end than most of the (cheaper, at least) alternatives.
The most important thing that hasn't been mentioned so far is - you want to make sure your bath trap is accessible in the future! So you need to incorporate an access panel. Schluter have a good solution for this called REMA - magnetic brackets that mean the panel is virtually invisible.
So I don't really see the point for these ready made bath panel kits. Just frame out and board so that your panel corresponds to the grout joints either side of where the bath trap is.
Waluigi
I assumed the OP wanted a large tile backer board so the whole thing can be removeable.
Time's Ran Out
5.5mm plywood is too thin to tile on and certainly no need for fancy fittings there!
Reply to Tiling a bath panel ??? in the Australia Tiling Forum area at TilersForums.com
Hi all, I am planning to tile a full height panel of split face tiles to sit 3” behind a log...
I've got an AKW Tuff form shower tray with a waste that is 10mm above the tray when fully...
