Discuss Tiles won’t stick to bsa membrane in the Tanking and Wetrooms Forum area at TilersForums.com.
One Day
I think many plumbers merchants are still supplying devil's flypaper because it's simply old stock.
I've been presented with it recently and sent it back to exchange for the new one (which is better but still rubbish in my opinion)
Dumbo
Do you not use membranes or do you use them but a better one in your opinion
widler
I’ve only used impey and another, (I’ve only done about 10 wet rooms )no idea which ones they were,but I most defo preferred the impey way than any other , although impey is hard work , I prefer it to paste
Krystie
Hi guys many thanks for all your response it didn’t say with the instructions to prime the membrane on top but we primed underneath what would we prime on top with going to lift all the tiles it’s got a wet room former underneath the membrane
Krystie
Bill
A tiling primer - if you are happy with the Mapei adhesive then use the mapei primer. you can buy it 1kg bottles and that is all you will need.
PRIMER G - https://www.mapei.com/gb/en/products-and-solutions/products/detail/primer-g
Time's Ran Out
Although primer G is an excellent product , I see no need to add another layer of any primer to a waterproof membrane. Just make sure it’s clean an dust free. IMHO the tile adhesive is meant to fix direct to the membrane.
What type of adhesive did you use 1st time round?
Reply to Tiles won’t stick to bsa membrane in the Tanking and Wetrooms Forum area at TilersForums.com
Teejay
