Discuss Thin Porcelain (attention Is Dangerous Use Google Translate) in the Australia Tiling Forum area at TilersForums.com.
what covarage did you get on the two and how did you test this ?
if I understood.
floors and walls bathroom, kerlite 3 mm, size 1000x3000, 1800x1000 max cut. adhesive mapei ultralite s2.
7 mm for the wall. 3mm trowel for tile.
My opinion is 3 mm thick, better s2.
4/5 is good s1.
I could be wrong, the teacher is you.
Antonio, I think Ray is asking,
How much adhesive covered the tile when it was laid.
Did adhesive cover 80% of back, or 85% or 90% or
100%?
This is Ray's question in this picture. This picture shows Gary and me testing how much coverage was on back of the tile. (Sorbo is standing haha)
We spread on floor and we spread on tile, after laying tile, we picked it up again to see how the adhesive covered the tile.
Compry?
Did you test?
I think this is Ray's question.
I
Italy
100%?
Compry?
View attachment 79867 View attachment 79868
Did you test?
thanks marc.
I'm impressed you cover s2.
all tile was covered, no rows of trowel.
laid a slab without double buttering (for trial).
It remained on the wall, because it was ok. hahaha
PS your photo is the 50/70%?
thanks marc.
I believe was S1 Tilemaster setaflex standard set, not rapid.
I can't remember exactly but maybe 10mm to floor, 4mm to tile.
When Ray see this post I am sure he will correct me if it is incorrect!
I
Italy
TP lines on the back, you intend cover?
or coverage, you intend where not see lines trowel?
which thickness is tp 3 or 5 mm?
laws attached data sheet ultralite s2, all compry :)
I
Italy
100%?
Compry?
Did you test?
floor seems 5/7 mm
I
Italy
we use closed tooth trowel for the floor antonio and a 4mm on the back of the tile we tried the mapei ultralight s1 at grespania training day and wasn't impressed this is the sort of coverage we get with Tilemaster seta flex S1
Ultralite s1 never used.
tile of the picture is covered 100%.
But is little :)
yes ultralite s2 is as a your picture.
I usually do the contrary 7.8 mm on the wall, flat tiles. (TP 3 mm thick, I also rear 3mm)
also carry out a shave to substrates, because in Italy walls and floors are made sand cement or premixed, therefore very rough
Spud
But is little :)
do you have any pictures showing the coverage of ultralight s2
Reply to Thin Porcelain (attention Is Dangerous Use Google Translate) in the Australia Tiling Forum area at TilersForums.com
