Discuss Thin Porcelain (attention Is Dangerous Use Google Translate) in the Australia area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Italy
Hello to all,
I wanted to open a trend regarding TP (thin porcelain).
I would like to focus here, all your experiences.
I am old but curious. and I want to know everything.
Use google translated (is ignorant).
if you do not write well bear with.
thanks antonio
Italy
i start,
last update Mapei course that I attended.
there was talk of new products ultralite s / 2 new lightweight adhesive and Mapelastic turbo.
Mapei says to lay T.P. is recommended ultralite s / 2, with drawing up in the same direction is on the wall / floor of TP.
this rule has been agreed with Kerlite, a major manufacturer of tp in italy
Italy
what covarage did you get on the two and how did you test this ?
if I understood.
floors and walls bathroom, kerlite 3 mm, size 1000x3000, 1800x1000 max cut. adhesive mapei ultralite s2.
7 mm for the wall. 3mm trowel for tile.
My opinion is 3 mm thick, better s2.
4/5 is good s1.
I could be wrong, the teacher is you. :)
if I understood.
4/5 is good s1.
Antonio, I think Ray is asking,
How much adhesive covered the tile when it was laid.
Did adhesive cover 80% of back, or 85% or 90% or
100%?
This is Ray's question in this picture. This picture shows Gary and me testing how much coverage was on back of the tile. (Sorbo is standing haha)
We spread on floor and we spread on tile, after laying tile, we picked it up again to see how the adhesive covered the tile.
Compry?
Did you test?
I think this is Ray's question.
Italy
100%?
Compry?
View attachment 79867 View attachment 79868
Did you test?
thanks marc.
I'm impressed you cover s2.
all tile was covered, no rows of trowel.
laid a slab without double buttering (for trial).
It remained on the wall, because it was ok. hahaha
PS your photo is the 50/70%?
thanks marc.
I believe was S1 Tilemaster setaflex standard set, not rapid.
I can't remember exactly but maybe 10mm to floor, 4mm to tile.
When Ray see this post I am sure he will correct me if it is incorrect!
Italy
TP lines on the back, you intend cover?
or coverage, you intend where not see lines trowel?
which thickness is tp 3 or 5 mm?
laws attached data sheet ultralite s2, all compry :)
Reply to Thin Porcelain (attention Is Dangerous Use Google Translate) in the Australia area at TilersForums.com
Apatel
