Should I have used SBR to prime on top of floor levelling compound
R
RWB
Hi all,
I've been reading all your helpful advice to everyone, so after tearing my hair out for most of the day thought I would sign up. Please could someone clarify if I should've used Cementone SBR on top of a self levelling latex floor compound. I originally stripped the old kitchen floor and all signs of adhesive etc. I then used SBR to prime and seal before applying the self levelling compound. This was down for a week and got a little dusty etc, so I decided to prime with SBR again. My initial reason for doing this was to stop the water getting sucked out of the adhesive (probably a stupid reason I guess). I used a 1 part water, 1 part SBR mix. The issue I have is that some areas seem to have formed a skin. Not massive areas, just the odd 3 or 4 inch patch here and there. I'm wondering if I shouldn't have used the SBR, or whether my mix was not diluted enough, thus leaving me with a bit of rubberising here and there due to it not sinking in. I plan to use a cement based adhesive over this, but am now worried as to whether I should try and remove the SBR, or maybe pour more self leveller over it and then tile directly onto that.
sorry for the immediate request for advice. I'm just at a loss as to what to do.
cheers
Rich
Cheers for the quick response. I knew deep down I had messed up, so have nearly finished sanding it all off now. Will start tiling tomorrow. Thank you both for your advice, I won't bother priming this time, if only I'd done the 4:1 mix in the first place, a waste of a day.
cheers again,
Rich
RWB,
RWB,
RWB,
RWB,
