Discuss Resealing between tile and shower base -large gaps in the UK Tiling Forum area at TilersForums.com.
R
radi
Hi Folks
I hope you had a good new year.
I am in the process of resealing the gap between the base of the shower tray and the tiles immediately above. However, the tiles have been cut quite short leaving a substantial gap to fill.
Do you fill the gap with just sealant and smooth off, or can you fill the main gap initially with grout and then seal with sealant.Any other ideas appreciated.
R
radi
Geez guys--Photos would really test me (i would need to work on that one) but I have measured the gap and I would say around 9mm
R
radi
Would you recommend replacing the bottom tile -- installed several years ago and no doubt I will struggle to find a replacement?
Reply to Resealing between tile and shower base -large gaps in the UK Tiling Forum area at TilersForums.com
  • Poll
