PVA V PRIMERS – WHy you should never use PVA Glue when Wall Tiling
Dan
Admin
Don’t listen to that idiot on handyman can. lol He’s an idiot who doesn’t have a clue when it comes to tiling. MANY PEOPLE THINK THAT P.V.A. IS OK AS A PRIMER ON WALLS AND FLOORS SO I THOUGHT THAT I WOULD LET YOU SEE THIS AND HOPEFULLY IT WILL ENLIGHTEN SOME NEWCOMERS OR EVEN […]
The post PVA V PRIMERS – WHy you should never use PVA Glue when Wall Tiling appeared first on Tile Blog | Tiling Advice - Tilers Blog on Tilers Forums.
PVA V PRIMERS – WHy you should never use PVA Glue when Wall Tiling | Click here to read more
PVA is the number one builder's choice, unexperienced tilers, plumbers, bath fitters use that as well. It is a huge error within the building industry. The PVA is water soluble, therefore, soon as the moisture kicks in the tile falls off the wall. I have encountered loads of failed tile jobs due to using PVA as a primer.
The alternative to PVA is the SBR which you buy at the local tile shops
Tilers Talk - Any Country
Tile Marble Granite,
