Discuss Ply floor - UFH - Ditra mat - Tiles in the Australia Tiling Forum area at TilersForums.com.
TJ Smiler
Hi there
1st time poster - long time lurker so be gentle!
I'm in a bit of a quandary and would be grateful for some advice.
Currently have a new ground floor extension being completed (kitchen and bathroom) around 25 sqm in total.
The kitchen part is 18mm ply (external I'm told but not sure) and the joists underneath have been made narrower to provide greater stability with extra noggins all around esp at joints and with screws at every say 200mm. The floor is stable and there is no movement. I've noted however that in some places the ply has expanded (maybe some water dropped) at the edges so that some are overlapping other joints (laterally not vertically). So will have to ask builder about that.
I intend to install either retrofit water based or electric mat UFH and then porcelain tiles on top.
My questions are as follows:
1. I am worried from reading on forums that 18mm ply may not be a sufficient enough base and further ply can expand and contract at different rates to the tiles which can cause cracks. I therefore intend to put Warm Up insulation boards on the floor and then the electric UFH on top. Is this sufficient or do you think I need to use a ditra/durabase mat product?
2. If I go for the retrofit water based UFH (from Wunda floor) on top of the ply these pipes comes embedded in a polysterine insulation mat which I can tile direct on top of. Do you still think I need ditra/durabase over this?
3. Assuming I go for electric what would be the best method? i.e. insulation board then UFH then Ditra or vice versa? Also what adhesives are recommended?
4. I have purchased BAL flexi tile adhesive for the tiles - is this suitable for ditra/surbase mat?
Sorry for all the questions but the builder seems a bit clueless and just wants to finish the job quickly and is relying on me to tell him what I want so I'm having to learn very fast!
Thanks in advance all.
Where abouts in London are you, i can come and have a look and give you a quote if you like or i am sure somebody else on here local to you will do the same......... if your builder is clueless then for christ sake don't let him carry out the work, you are asking for problems.
Type Sparkles bathroom into our search box and read..... Don't make the same mistake
U
Uheat - Keith
Agree with others here.
Insulated Construction boards, Electric Under Floor Heating, a powdered flexible self-leveling compound to cover the underfloor heating and fix the floor finish.
Warm regards.
Sean SML Tiling
Why dont you fit insulation boards such as marmox then use schluters new ditra heat which is an excellent product and you dont need to self level.
Q
Qwerty
I would advise the same, but feel it would be a lost cause as his builder has no idea about tiling and UFH it seems, let alone any ditra product! Hence why I said right at the start to get experts in!
Reply to Ply floor - UFH - Ditra mat - Tiles in the Australia Tiling Forum area at TilersForums.com
