Discuss Outdoor 20mm Porcelain 60 x 60 slabs How to install ? Help! in the DIY Tiling Forum area at TilersForums.com
What is best way to lay outside 20mm Porcelain patio,
Would I compact soil, add hardcore and compact (How deep for hardcore) then add slurry mix of 4 parts sharp sand and 1 part concrete and lay tiles on top or as someone suggested set concrete base on top of hardcore and glue down using 5 mm spacers for brush in grout. Any advice would be most welcome, thank you regards David
Alan Bentley
I did one last year/early this year.I bedded on to a cement base,also you’ll need to prime each tile reversel side,with SBR mixed with cement mix,paint it on,3-4 inch hardcore whackered down,i then used a resin grout which you brush/force in to joints,this sets solid,no mess,sweep up excess.
Reply to Outdoor 20mm Porcelain 60 x 60 slabs How to install ? Help! in the DIY Tiling Forum area at TilersForums.com
Similar threads
Hello you Pro’s out there. I am embarking on replacing my current outdoor patio concrete slabs with Porcelain Slabs...
  • Question
I have removed my old patio 60cm x 60cm concrete slabs which started from the back door of my house to the start of...
Hi there I’m new to Tile Forum and joined to get professional opinions because I really need advice. We laid 100m2...
Hi Lou and Slippery Just got the messages. I went for fibres in the screed and told the customer I would tile it in...
Good question! I have just posted a similar thread. I guess the lack of any answers says a lot, people just don't...
This website is hosted and managed by Untold Media. Creating content since 2001.
Latest Post
Thanks for visiting TilersForums.com, formerly known as TilersForums.co.uk.
Search Forum
