WetSaw
It's often easier to overboard, you then have a perfectly flat and plumb surface.
Discuss Old plaster came away, render looks solid and flat what do i need to seal it with prior to tiling? in the DIY Tiling Forum area at TilersForums.com.
Ive never tanked an area before.does it consist of taping the plasterboard joints and then painting the area with a waterproof sealer?
But is it cheaper once you tape the joints and waterproof screws ?But I'm with you in that i would fix tile backer board if I was at that point .At £50 for a tanking kit it would be cheaper to fix Wedi board .
Reply to Old plaster came away, render looks solid and flat what do i need to seal it with prior to tiling? in the DIY Tiling Forum area at TilersForums.com
