Discuss Mosaic compression in the DIY Tiling Forum area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Wstarw
Hi all
I plan on using a 300mm wide strip of mosaic (the kind on a webbing backing), half way up the wall. It occurs to me that the tiles above may compress them and everything might slip and become misaligned. Is this a concert and if so, how can I address the issue?
Thank you
L
LM
Hi all
Thank you
Research the ‘dog tooth’ method.
Time's Ran Out
300mm May be a bit wide for the old dog tooth but thin Wedi will work to build out the thickness required from the mosaics to the tile thickness.
Reply to Mosaic compression in the DIY Tiling Forum area at TilersForums.com
mcgtech
