Discuss Laying 10mm tile in the Advice Forum for Australian Tilers area at TilersForums.com
waynenort
Reactions
Melbourne Australia
What member type are you?
Homeowner
Laying 10mm thick floor tiles on 6mm cement sheet underlay in the bathroom.
Will the metal edge trim also be 10mm inside depth?
Also the bathroom exits to the hall which has an oak timber floor. So the bathroom floor depth will be 16mm (tile+underlay) higher than the hallway floor. Would a10mm inside depth L shaped tile trim still be ok?
Or would I need to use a different profile trim to cover the 6mm cement sheet edge?
Or will this 6mm gap under the L shaped trim edge be corked?
Dan
Dan
Admin
Staff member
Reactions
5,262 27
Staffordshire, UK
DIY Wall and Floor Tiler
I'd use a slightly rounded / flat door strip that you screw to the sub floor so it becomes a small ramp. That small step otherwise is too small to notice as q step but too big to not trip up.
Some members make a nice wooden strip themselves and stain it to match the door if that's stained/ varnished.
Otherwise a 10mm L strip will be 10mm on the outside, not inside, i think.
Dave
Dave
Staff member
Reactions
2,159 1
Co.Durham
You will be able to get a finishing trim to suit the hallway floor , leave a rebate of around 12mm and then glue the trim in situ. Its profiled as to suit the slight height difference, should be available from the wooden floor retailer
Sean Kelly
Sean Kelly
Supporter
Reactions
652 1
Ruislip
Some of the independent tile shops will usually have a trader that only lays wooden or laminate flooring. These guys can normally make a door threshold to your exact requirements. Look at paying £50+ for this.
However, if you are handy you can pop down to Homebase and buy some profiled lengths of wood (usually softwood). You should be able to make your own and maybe stain it the same colour as your oak floor.
or
Buy a 16mm tile trim (special order) to cover your tile/adhesive/6mm cement board. 16mm is not a massive height difference as you normally walk across a door threshold not on it.
waynenort
Reactions
Melbourne Australia
Homeowner
  • Thread Starter Thread Starter
  • #5
Thank you for the advice Dave and Sean. Much appreciated and problem now solved. Looks good too.
Reply to Laying 10mm tile in the Advice Forum for Australian Tilers area at TilersForums.com
New Threads (Sitewide)
Top Bottom
Use TilersForums.com to find Tiling Jobs or your Local Tilers for free. Get tiling tools at the best prices via the forum.
