Hi I'm going out to price a conservatory floor today. Customer wants electric ufh. Floor is concrete. I was going to lay marmox then wires covered in slc. Is ditra overkill or would you use it? Tiles will be either ceramic or porcelain.
Perfect cheers. Yeah its ctd I use. They said they only do contract boards and hardi. Never used their contract board before so not sure what it is.Dave do you use CTD up your way??
If you do get the Jackon boards as a lot cheaper than marmox.
It will need to be 10mm boards for sticking to concrete, if any thinner they need fixed with screws & washers.
I wouldn't use Ditra as the thermal boards will give u a bit of decoupling from the base.
Sorry stef my mistake. I believe they are jackon boards.Perfect cheers. Yeah its ctd I use. They said they only do contract boards and hardi. Never used their contract board before so not sure what it is.
Yeah they are m8, good to use, I'm using them more & more over Hardie. Easier to handle & cut & as stated they will decouple slightly from the base.Sorry stef my mistake. I believe they are jackon boards.
Nice one. Just been to see it. It's actually a chipboard floor so just going to do the same prep but glue and screw 6mm board.Yeah they are m8, good to use, I'm using them more & more over Hardie. Easier to handle & cut & as stated they will decouple slightly from the base.
