Discuss How to cut tiles around an arched window in the UK Tiling Forum area at TilersForums.com.
C
Chris Cooper
Hi, I've been tiling for 9 months and have finally encountered an arched window. Any advice on getting a nice cut around the arch? (don't need to go inside it). Was going to nip some plastic corner trim until I could bend it around the arch but this is proving difficult as well. Window is 970 wide. Help!
P
Perry
if you cut the trim as far as u can and as many cuts as you can then back fill the trim with filler:pete
G
guy1976
i would use pieces of paper cut the same size as the tiles and use them as templates for the curve for trim i would buy the homelux ctd sells or the tops trade trim as both are very flexible and just cut the back and bend around and hold in place with staples
Reply to How to cut tiles around an arched window in the UK Tiling Forum area at TilersForums.com
