How best to Tile a room?
I bought 120 packers and the primer, and a multimeter to test the cables are ok, I should of tested them before putting the slc over, still worth doing now before another 10 bags and adhesive and tiles go over though.
If everything does go to plan my feet better be grateful for all this hardwork, When you see that the heating system costs around £450 with fancy thermostat you think that's the majority of the cost, but if you add everything else up it's actually the cheapest part.
I hope to do my prepping Friday and pour Saturday, so i'll upload photos when it's done, thanks.
🙂Almost the same job,65 sqm 900x900mm,starting yesterday with SLC,finish tomorrow.Asda-save money every day!
[/ATTACH] IMG_1622.JPG IMG_1635.JPG IMG_1625.JPG
nice job, how'd you get on with the levelling clips, any tips?
Don't expect too much from the clips, they're more about holding tiles in place while the adhesive sets than levelling the tiles.
They're designed to break away after, so applying too much force will break them before you've even set them.
What system do you have?
Yeah for that type of system they're the best available.
But you still need to set the tile to its correct position before tightening them.
But what they'll do is guide you as to where the tile needs to be, because they won't tighten correctly unless the tile is set right.
Does that make any kind of sense?
You need to make sure that you mix the adhesive with the maximum water content as stated, and keep mixing the bucket throughout, to keep the adhesive as loose as possible.
DO NOT add extra water after the initial mix if it starts to stiffen, just re mix it and it'll loosen up again, unless it's at the point of setting.
And you will need standard set adhesive, not rapid.
Yeah for that type of system they're the best available. really? strange, very strange ...🙄.
hello, I did have one question about the packers, I understand that I need to ensure the packers are level starting from the high point, going across, but I am wondering if for example I have 3 row of packers at 600mm intervals, do I need to ensure that the 1st row of packers is exactly level with the 3rd row of packers, using the level up the room & diagonally? I did a quick sketch to show what I mean.
Yes, working from the high point, the packers should all be level no matter where you put your level. So say your corner packer is the high point then the next row along should be level.
So effectively once you have fixed all your packers it shouldn't matter where you put your level on top of the packers it will be at the same height as your corner point
All the packers would be placed level with the very first one laid, so if you placed three more down at 600mm intervals, the first maybe 3mm high off your floor,whereas the second and third maybe 6mm and 2mm respectively.
You only need a 1-2mm packer at your start point, just high enough to give the minimum thickness as stated on your bag of slc.
If it'll go from feather edge to its maximum, then 1mm would suffice.
As others have mentioned tho, the thinner it is the more difficult it is to get flat and the quicker it will begin to dry, and you need to keep a wet edge, as you've found out.
Snap! 😀
Yeh to go over the Slc in preparation for the next layer, I'll need to mix with 3 parts water won't i?
DIY Tiling Forum
mp3wizard,
Time's Ran Out,
mp3wizard,
Time's Ran Out,
