Herringbone walls ! The definitive answer?
Mirror it, it looks ok
If you mirror the points may look a bit odd but like you said no little bits.The thing that I would check is where does each pattern finish on the tray edge If square it should look pretty much the same as the back wall you have already done.So visually mirror may look better in this instance.
Re-clad the sill and side reveal of alcove to give me nicer cuts.
Toyed with the idea of building out the right-hand side reveal to totally equalise it all, but I've already shrunk it down and that would have meant losing a really big chunk of it.
Success with the most worrying part - going either side of alcove and meeting up again above it.
Really wanted to finish the main wall today as it was my first proper full day at it but didn't quite manage it. 5pm and I couldn't get out of there fast enough. Sick of it now to be honest 😡
Grey grout so no place for cheeky cheats 🙁
macten,
Weston,
macten,
Weston,
