Discuss Grout lines for same size tiles on wall and floor in the Canada Tile Advice area at TilersForums.com.
293
Leicestershire
hi
Quick question ..
I’m tiling an ensuite with 600x300 porcelain . Using a darker version of the wall tile on the floor. Given floor & wall tiles are the same size, I was thinking about 3mm grout lines throughout to keep a consistant look. What is the recommended / generally accepted method. The room is 1.9m x 1.6m . Also, portrait or horizontal & if horizontal, brick bond ? Tia
Andy Allen
1,318
Gloucester
As your using different batches of tiles you may find a slight difference in size.
However I would go 2 to 3 mm joint and landscape...
Reply to Grout lines for same size tiles on wall and floor in the Canada Tile Advice area at TilersForums.com
