Discuss glue for underfloorheating in the UK Tiling Forum area at TilersForums.com.
U
Unregistered
I have a large area to tile in my new house where we will have underfloor heating. I have been quoted a price for flexible glue, recomended for the job. This glue is a lot more expensive than the 'standard' glue.
I would like to safe some money and I have heard of additives that can make the standard glue flexible. Would this be as good as the recomended product (but just a bit more hassle when mixing the glue) or should I stick with what the tileshop is trying to sell me.
Has anyone any experience with this?
Dan
Admin
Hi and welcome to tilersforums.
You can either use and additive for standard adhesives or use the already modified adhesive, either is as good as the other, the flexible adhesive will be easier to apply though and I think you will find they work out about the same price once taking in to account the quantity needed to make a normal adhesive flexible.
I'd stick to the right stuff. It's what's recommended and it's for your heated floor, you don't want to scrimp and save in this area.
trevortine
I use bal rapidsetflexi on ufh admin and usually a bit of admix for good measure, i know its not essential but i tiled my own kitchen with this method then when the wife insisted we changed it you should have seen the bother trying to lift them! Nearly every tile had a skin of plywood welded on to it:rolleyes:
Reply to glue for underfloorheating in the UK Tiling Forum area at TilersForums.com
Hi All, I’m ripping out a failed existing tiled floor. Tiles had not been back buttered so...
Hi, I am trying to achieve a low floor build up including wet UFH over a new suspended timber...
Hi all. I came across this forum searching for info so my first post. I'm renovating 1890's...
Teejay
