Discuss Garage Floor Tiling Do's & Dont's in the Australia Tiling Forum area at TilersForums.com.
568
Guildford, UK
I think there are many ways to do this, we would recommend to expose the crack and fill with Flexible joint sealer (Flex PU40) and to check the levels first, if not perfectly
level (garage would have a slope) than you need to self level (Flowcrete 1-10 or 3-30) you should really make sure that the slab has got DPM otherwise the moisture will cause issues with SL as most of them contain lime.
Once tanked (Aquamat Elastic 2part) and leveled, depending on how big the crack you either de-couple (Isomat decoupling matt)and use flexible S1 adhesive (AK20) or you dont de-couple and use extra flexible S2 addy (AK25). For the garage we would recommend Epoxy grout (Multifil Epoxy)
Easily cleaned with water. Good luck
Lakey
478
Crawley
Thanks for the info.
I have obviously recommended SLC however by eye the floor does look like it has a slope to the door.
I think 'leveling' would create to much of a ramp at the front so I may suggest 'flattening' as opposed to 'leveling'.
Is the only way to check for a DPM by drilling a core hole?
P
Perfect Tiling
If the floor has a slight slope to the door I would leave it like that....its for a reason and usually required in garage design. When you park your car after driving in the rain or snow any water will run out under the door rather than form dirty puddles in the garage. If there is a crack and you want to be safe and use a decoupling mat look at the BAL mat...its a thin layer construction and isn't effected by compression loads. It isn't a waterproof mat though so you would need to ensure the DPM is there.....it should be if its a new build property.
Lakey
478
Crawley
Yes agreed.
I'm planning on 'levelling' the floor left to right but maintaining the fall from back to front.
P
Perfect Tiling
I would probably leave it as is....It'll keep any water away from the walls if the floor slopes into the middle. Most garages have stuff stored by the walls and if the floor is level water will get under
Lakey
478
Crawley
Know what you mean but it will need a certain degree of leveling as 300x300's will really emphasis the 'lumpiness' of the substrate!
Reply to Garage Floor Tiling Do's & Dont's in the Australia Tiling Forum area at TilersForums.com
