A
Andrew Case
Once the joists are in and solid with regular noggins then as long as the base thickness on top is 2 layers THEN the tiling starts, that will be fine I think. Should be solid.
Make sure to use pressure treated timber and if poss soak the posts where they enter the ground in creosote or substitute. Belt and braces.
