Correct Tiling Trowel for 300x600 floor tiles
I
Ianc9101
Morning all, Hope I am posting in the right area and not in the DIY area
I am planning to do my first ever floor tiling DIY job soon. Went into Topps and bought a 8mmx8mm tiling trowel (after speaking the advisor) with my tiles (Qrock Black) but now not sure if it is the right choice. I will be tiling 300x600 tiles directly onto concrete and the tile thickness is 9mm. Concrete Floor is nice and level. It seems on here that the pros suggest using a 10mm notched trowel, am I correct or would my 8mmx8mm do the job? If not do I need to buy a 10 x 20mm notched trowel like from Screwfix or somewhere
Many thanks
An 8mm back buttered with 8mm at 90 degrees to the floor ribs will be plenty as long as the floor is has level as you say. Make sure you twist the tiles into the adhesive. Lift a tile now and again to make sure you are getting good adhesive coverage.
Just seems to give me good coverage, believe me the amount of trowels I have sitting in my lock up that are tried and tested and now in dry dock.
Best Floor Tiles
Ianc9101,
andyb1,
Ianc9101,
andyb1,
