Discuss Can Electric Ufh Pads Be Applied Directly Over Cork Flooring? in the Tiling on Underfloor Heating area at TilersForums.com.
David Chambers
Hi. Newby here. Looking for advice on UFH over cork tiles.
Just bought this house, previous owners have (6mm) cork tiles over laminate laid directly on concrete. I want to put electric UFH down, can I use it directly over the cork floor? Has anyone ever done E UFH directly on to cork flooring? I've read some blogs that state max 81 deg F for wood flooring above, is this due to the expansion/contraction of wood due to heat/cold/moisture? See any issues with what I propose? Any advice/experience would be appreciated. Cheers.
StevieBoy
Yep, as has been said - take it up, lay insulation boards, lay heating then tile with 2 part for me.
Reply to Can Electric Ufh Pads Be Applied Directly Over Cork Flooring? in the Tiling on Underfloor Heating area at TilersForums.com
