Discuss best sealer for travertine?? in the UK Tiling Forum area at TilersForums.com.
basshunter
anyone got any favourites in terms of performance/price/how long it lasts etc??how much will i need for 40m2 of honed and filled trav?
-another pricing lesson learnt:lol:
simonb43
Topps do a sealer for travertine. think it might be a 500ml bottle, around £25 and i think it covers 20m2.I'm not certain, but it gives you an idea of the cost. Make sure you advise customer that it is their cost, not yours. Gaz @ Topps will give you the proper price. Good luck
Dan
Admin
1,318
Staffordshire, UK
Checkout Sure Seal spray - apparently really quick to use and does the job perfect. I'm pretty sure you can use it on any tile.
Thought there are a few names that come recommended - Gaz flogs one in topps that's good. He'll post later no doubt. I forget the name of it now.
beat me to it lol.
DHTiling
I use lithofin stainstop....great product...as are most makes.....its best to use an impregnating sealer and not a topical ( coating) sealer as this last longer and protect better....topps sell Fila products and they will be fine as well....
basshunter
i like the look of the lithofin dave.is there a trade outlet you use?
been looking at sealers choice gold too.98 quids for 3.75l....with 40m2 to seal im thinking i will need 4 litres at least
argh!!!
DHTiling
You can buy it on line at Extensive limited but i get mine from my local CTD branch..
Here,s a calculator for working out how much sealant you will need for certain types on stones.....this is for lithofin products but should roughly work the same for other makes as well....
[DLMURL]http://www.extensive.co.uk/product.php/56/0//ecc9ea0c1d7bbd5e390eac1b7d46f66a#calculatorAnchor[/DLMURL]
R
russ
lithofin for me too :thumbsup: ( make sure the rooms well ventilated or you will end up high as a kite):grin:
P
Proper Job
i Have used loads of different sealers for natural all giving different results there each to there own some bring out the colours more than others, i would not recommend sealers they just coat the surface, impregnators are the best.
Bal do a very good tile sealer and its pretty cheap soaks in well and wipes off easy.
lithofin and Fila are top quality impregnators and sealers you can't go wrong with there products, HG and Aquamix i'm not to fond off they darken light colours to much and dry like treacle.
Just remember to follow the instructions its normally leave for between 5 - 20 mins depending on product and re apply. Then do a test with water called the 30 second test. IF the water stays on the surface after 30 seconds they are fine.
Its a must that you clean all the natural stones before applying the impreg or sealer. I have tried a sponge roller, paint brush and jay cloths.
Jay cloth is about the best on large format tiles and a paint brush for natural mosaics.
Also use a decent quality grout a course grout can scratch the surface of some tiles. I Don't use mapei products i go with bal which have never failed or reacted. 1mm spacers if you can get them 2mm will be fine.
One last pointer is if you seal the tiles again after you have finished the job, it will change the colour of the grout, plus u need to make sure all the grout dust or haze has gone. I normally say to the customer do it once a year in a bathroom or when needed in heavy trafic area's.
If you leave the sealer to long use white spirits to clean excess off.
Hope this helps i have done loads of natural stone with great success
basshunter
hg impregnator 16 quid a litre.lithofin mn 36 quid a litre....massive price difference.i hope the hg gets me as high as the lithofin:lol:
thanks for the input.good forum this
Reply to best sealer for travertine?? in the UK Tiling Forum area at TilersForums.com
