Discuss any seal product to cover large gap between tiles and shower tray?? in the UK Tiling Forum area at TilersForums.com.
macten
Points
1,158
Nottingham
Don't touch seals - they leak like a sieve in the corners!
beanz
Points
1,003
Berkshire
Surely if you get plenty of silicone behind them, then silicone the outside too, they should be fine. Admittedly, when i used the window trim i had tanked behind it, then siliconed behind and on top. Looked great! Wish i'd taken a photo now... :oops:
macten
Points
1,158
Nottingham
I've fixed 6 leaks in bathrooms with this stuff on, takes ages to get off as loads of silicone behind and on top.
3 were seals made for ontop of tile, 3 were made to go behind tile.
All leaking like good ones in the corners - don't touch the stuff - plus they go mouldy and discoloured real quick.
beanz
Points
1,003
Berkshire
Interesting to hear. :thumbsup:
aflemi
Points
513
What would you recommend Macten? I had been starting to like the sound of the 'window trim' with tanking behind and siliconed top and bottom. Corner obviously a potential problem area, but I think if it's monitered and any failure rectified quickly then it could be the best bet. Can't raise shower tray as its a quadrant so impossible to fill the curved gap which would be left.
ps can't risk removing tiles as no spares.
beanz
Points
1,003
Berkshire
Make sure you silicone behind the trim (If you end up going down this route), as well as top and bottom, if only to hold the trim in place. ;)
CON5933
I understand what you mean Mac, but i've never had a problem with them.:thumbsup:as long as they are sealed properly and the substrate is protected..
as far as discolouring goes....oh ok then:smilewinkgrin:
macten
Points
1,158
Nottingham
Well if you can't raise tray or replace better fitting tiles then I guess you will have to go this route.
Get you're internal mitres absolutely spot on and use LOADS of silicone and don't use shower for 48 hrs.
Time's Ran Out
I thought my option in post 4 was a possibility!
What colour are the wall tiles in the shower - Gulf Stone is normally black - so any trim/window seal will stand out a bit!
Another option is a Cristal bath trim set of moulded quadrants - they use to make them in all colours inc black, but you might only get white these days:thumbsup:
macten
Points
1,158
Nottingham
Sorry Timeless - genius idea if he has spare tiles for skirting :thumbsup:
Reply to any seal product to cover large gap between tiles and shower tray?? in the UK Tiling Forum area at TilersForums.com
  • Poll
Hi, I have a small en-suite 1200 x 2400, with a 1200 x 900mm linear drain tray which will have...
