Discuss Adhesive Question in the America area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Hello, looking for some advice on a DCF. I am tiling onto existing tiles with new tiles, porcelain 60 cm x 30 cm.
I intend to use NX standard set powder, which is suitable for porcelain tiles as it is cement-based.
do I need a special adhesive When tiling onto existing tile, if so what brands, thank you.
Dave
Walls or floor ?
Your first issue is the wall substrate can only hold a certain amount of weight and adding more weight could well result in a failure.
The old tiles are well fit. But how would you if the substrate or wall underneath would fail?
Is it a case of trial and error?
Just pointing out a possibility 👍.
as for getting them to bond , a primer like eco-prim grip is a recommended product by Mapei
Thank you mate!
I appreciate the reply and advice. I do have primer already etc. Is there any additional prep needed to rough the tiles up etc? Or just a good bed of adhesive and proper fitting.?
Reply to Adhesive Question in the America area at TilersForums.com
laattaana
