Discuss Cutting porcelain tiles diagonally in the Canada Tile Advice area at TilersForums.com.
StuVin
38
Buckinghamshire
Hi, I am trying to cut 600 x 600 porcelain tiles diagonally corner to corner on my bridge saw. Upon making contact with the tile, the edge chips leaving an unsharp cut at the start. Do you have any suggestions to avoid this. Could it be a sign that the blade has lost its edge? Cutting across a tile 90 degree to the blade leaves a clean cut throughout.
Kind regards,
Stuart
StuVin
38
Buckinghamshire
Thanks Julian, I was thinking of trying a few passes as you have suggested. Would you suggest 5mm depth at a time, or would you make the first pass only a couple of mm.
Maybe it’s just trial and errror.
Kind regards
Stuart
J Sid
yes , about 5 mm then with grinder cut right though the tile at both ends then wet cut the rest in a few passes.
StuVin
38
Buckinghamshire
It worked well today, so thank you
The cuts are on show so I wanted to get them good.
If I wanted to put a chamfer on them like the rest of the tile edge, how would suggest I go about it?
Concrete guy
A chamfer can be created with diamond hand pads, an electroplated diamond vanity blade (on a variable speed grinder) or coarse polishing pads and a polisher/variable speed angle grinder.
Hand pad = slowest but most control
Vanity Blade = This is what masons use to chamfer granite worktops mostly.
Polishing pads = An alternative to an EP vanity blade.
Reply to Cutting porcelain tiles diagonally in the Canada Tile Advice area at TilersForums.com
  • Poll
