Discuss Cutting porcelain tiles diagonally in the Canada area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
StuVin
Hi, I am trying to cut 600 x 600 porcelain tiles diagonally corner to corner on my bridge saw. Upon making contact with the tile, the edge chips leaving an unsharp cut at the start. Do you have any suggestions to avoid this. Could it be a sign that the blade has lost its edge? Cutting across a tile 90 degree to the blade leaves a clean cut throughout.
Kind regards,
Stuart
StuVin
Thanks Julian, I was thinking of trying a few passes as you have suggested. Would you suggest 5mm depth at a time, or would you make the first pass only a couple of mm.
Maybe it’s just trial and errror.
Kind regards
Stuart
J Sid
yes , about 5 mm then with grinder cut right though the tile at both ends then wet cut the rest in a few passes.
StuVin
It worked well today, so thank you
The cuts are on show so I wanted to get them good.
If I wanted to put a chamfer on them like the rest of the tile edge, how would suggest I go about it?
Concrete guy
A chamfer can be created with diamond hand pads, an electroplated diamond vanity blade (on a variable speed grinder) or coarse polishing pads and a polisher/variable speed angle grinder.
Hand pad = slowest but most control
Vanity Blade = This is what masons use to chamfer granite worktops mostly.
Polishing pads = An alternative to an EP vanity blade.
StuVin
Thank you ATS, I only have three tile edges to do so I may look at using a hand pad. Are you able to provide a product name and part number?
Kind regards
Stuart
Concrete guy
Kind regards
Stuart
I can't provide links back to our website on forum (advertising etc) but some of the other members will be able to point you in the right direction.
StuVin
Thank you guys, you’ve been very helpful. Is there one grade of hand pad that will do the trick to create the chamfer or will I require multiple grades?
Kind regards
Stuart
Reply to Cutting porcelain tiles diagonally in the Canada area at TilersForums.com
Apatel
