Waluigi
Quite possibly Yes
Discuss 1200x600x10mm porc on walls in the Canada Tile Advice area at TilersForums.com.
Either my eyes are starting to go or those shots were taken with Johns Pin Hole camera.
You forgot to blur your face I can’t unsee it now!First image, Garythetiler, myself and a bit of Mark, (whitebeam)
This is what you want to see, no serrations as such, bearing in mind it wasn’t 100% bedded, wouldn’t have been able to lift it otherwise.
Second image, what you don’t want to see, a ptb was used and it clearly slumps away , leaving areas with no adhesive at all.
You get the idea.
View attachment 105037 View attachment 105038
Are you smoking in the first pic?
Don’t smoke.Are you smoking in the first pic?
It’s a wonder you got that tile up without breaking itFirst image, Garythetiler, myself and a bit of Mark, (whitebeam)
You get the idea.
That you keeping Gary and and Marc right?That's a blast from the past
It is Mark, good to see you about again mate, you good?That's a blast from the past
Reply to 1200x600x10mm porc on walls in the Canada Tile Advice area at TilersForums.com
