Discuss Dressing beswick limestone slab.... in the DIY Tiling Forum area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Andy Allen
Got some beswick tumbled limestone slabs to do in the new year, I have to cut a curve in some of them and dress the edge, was going to use a polishing pad from ATS what grit would you recommend for limestone.
Or anything else that I could attach to a grinder and use...
Andy Allen
Silicon carbide #120 will give a honed finish.
If the edge is being seen and you don't want what appears to be a machine cut/finished edge then you could finish with silicon carbide brushes to give it more an aged appearance.
Can they be used with a grinder ?
Concrete guy
Better used on a polisher or variable speed grinder.
You'd have no control at 10,000 rpm+.
I always explain to people that the clue is in the name - a grinder is great for grinding (and cutting) , if you want to polish you need a polisher.
Andy Allen
As this is a one off job and I just need to dress 2 curves, would the hand polishing pads work ?
Concrete guy
Really it all depends what finish you want.
Wet and dry paper will work for a one off.
It's worth investing in a variable speed machine as it really opens up what you can offer the customer, I see a lot of guys on here use the Bosch one, which looks like good value for money for a few jobs.
Reply to Dressing beswick limestone slab.... in the DIY Tiling Forum area at TilersForums.com
Apatel
